With L98 which cam, mods inside???
Old Aug 23, 2001 | 09:03 PM
wordguy's Avatar
Hey I need help finding the right cam for my car. I have an 87 Vette and plan on porting all of the intake parts and installing headers and zero restriction exhaust. I have an Ed Wright chip. I also would like advice on which roller rockers, roller lifters, etc to get. My first purchase will be the cam, though. Then the headers. There are no cats or mufflers right now. Also what would be a good base timing to use, 6 is stock??? Any help from the knowledgeable would be appreciated. Oh and I am on a budget. Also would it work to wire my cold start injector to the other injector and run it to a toggle switch inside for when I anticipate a race?
Old Aug 25, 2001 | 12:03 AM
Matt383's Avatar
It depends on what your purpose for the car is. If going mild- a ZZ4 is a step up from stock as is the super profile L98. If you want a little more try the ZZ9, its even emissions legal. With anything bigger you need more work on the intake side, but the porting is a start.
Frozer!!!
Jan 19, 2024 04:55 PM
lt500r55
Sep 1, 2021 01:30 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
matthew911
Aug 12, 2015 09:38 AM
anesthes
Aug 8, 2015 09:37 PM
