Code 34
Old Aug 26, 2001 | 11:05 AM
MINN IROC-Z's Avatar
Car: 1988 IROC Z
Code 34
I have had this code show up every once in a while but has been showing up a lot more for no appearant reason. Usally if it shows up it is only on the first start of the day and then I would never see my SES light again. But lately it shows up almost every time I start it and don't matter wheter the engine is warm or cold. I have done the following modifications to it.
ZZ4 Cam
Ported factory heads with Manley valves
Ported intake and plenum
Cutt off bottom of airbox and put in K/N filters
Fuel pressure regulator changed to adjustable
180 stat and lower temp switch.
The engine runs great and kicks *** on low end and through mid range but the SES light gets a little anoying sometimes. I use a Auto X Ray to get my codes and check things out but this one has got me a little puzzled. Also do you guys think I would gain further benfits with a aftermarket chip and who is the best to work with on getting on made? Thanks for your help Dennis
Old Aug 26, 2001 | 12:03 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Check all the relays, and check your TPS voltage, try to set it a little higher if it'st too high already.
GTA -89:383, 4-bolt,Free flow muffler,dual 3" HF cats, Edelbrock headers, Canfield heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods,looking for a SR ...
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Aug 26, 2001 | 12:25 PM
jase's Avatar
code 34 is a vacuum circuit.Check your wires and connections.Might have to replace the vacuum sensor circuit.
Old Aug 26, 2001 | 12:49 PM
jase's Avatar
<font face="Verdana, Arial" size="2">Originally posted by jase:
code 34 is a vacuum circuit.Check your wires and connections.Might have to replace the vacuum sensor circuit.</font>
also if your car is a later model,this is a map sensor code.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
