Shuddering, Please Help
Old Mar 15, 2008 | 02:26 PM
slicef96's Avatar
Car: 1987 Trans Am
Engine: LB9 5.0 TPI
Transmission: Manual
I have an 87 T/A 305 TPI, Manual Transmission.
under light load it shudders. When you are just holding the gas to maintain speed at about 2000 RPMs it feels like it is running out of gas.
My thoughts are:
Clogged Cats
Fuel Filter
O2 sensor
Indectors
Computer
I am looking for both suggestions on what the problem may be and best ways to Diag it.
Thanks in advance
-tm
Old Mar 15, 2008 | 02:54 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Shuddering, Please Help
i would suspect a clogged cat. or fuel filter , or both . pretty straight fwd. on changing both . if you don't have emissions testing rod out cat. ( illegal to do but i won't tell ) felt a much better running car when i did mine .
Old Mar 15, 2008 | 05:27 PM
slicef96's Avatar
Car: 1987 Trans Am
Engine: LB9 5.0 TPI
I spoke to a friend and he pointed out that Fuel filter and/or Cats would limit top end and get worse with high RPM. If anyone has other thoughts I appreciate it.
Old Mar 15, 2008 | 05:41 PM
brp88gta's Avatar
Car: 88 trans am gta
Engine: 305tpi
Axle/Gears: 9 bolt 3:27
any check engine light? when was the last time it had a yune up? (plugs wires cap fuel filter timeing)
mfp189
Sep 27, 2015 09:25 AM
novaderrik
Aug 10, 2015 12:44 PM
91CamaroRS305
Feb 12, 2003 12:26 PM
spearson
Jan 8, 2003 09:13 PM
Rig
Apr 23, 2001 06:22 PM
