Holley stealth ram question
Old Mar 15, 2008 | 09:41 PM
BAD88IROC's Avatar
Car: 88 IROC-Z , 00 CAMARO SS
Engine: BUILT 5.7 IN THE IROC, STOCK LS1 IN THE SS
Transmission: 700R4 , 4L60E
I am currently looking to either get the stealth ram intake for the vortec heads or get the tpi base for the stock style tpi for vortecs. My question is will my stock tpi fuel rail work with the holley stealth ram? It doesnt really look like it will to me but according to summit racing there is no aftermarket fuel rail needed but they did suggest it. I was just wondering if anybody here has done this setup and can maybe give some very helpful info. Im thinking the stealth ram will be the best for the money mainly because of the extended rpm range over the tpi setup but i really love the TPI look. Any help is appriciated. thanks alot
Old Mar 15, 2008 | 09:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Holley stealth ram question
no TPI fuel rails will not work with the stealth ram. You need to buy the fuel rail kit for the stealth ram, its roughly 160-250 more bucks, depending on the regulator option you get
Old Mar 16, 2008 | 01:51 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
I think though that even though you have to buy the fuel rail kit that the Stealth Ram would still be the better option....finacially permitting ofcourse.
Old Mar 16, 2008 | 02:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
considering that the Stealth Ram with rails and fuel lines can be had for 650 bucks or abit less, thats a great deal considering TPI base is 360-400 and runners are 350-400 and you still wont get the performance HSR will offer
Old Mar 16, 2008 | 06:51 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
I looked into that, and according to the site, it says stock Vortec rails work... not sure what that is supposed to mean. The L31 Vortec doesn't have fuel rails so.
I decided to go with the Ramjet intake for my car.
Old Mar 16, 2008 | 07:54 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah not sure why it said stock vortec rails would work. You need the rails for the stealth ram...either the vortec stealth ram kit or non vortec if your not using vortec heads
Old Mar 16, 2008 | 08:25 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
http://store.summitracing.com/partde...w=32&N=700+115
that's the applications Summit lists the fuel rails as being for. Looks to be all just Vortec engines, unless they are for adapting the SCPI to port injection?
Old Mar 16, 2008 | 09:08 PM
BAD88IROC's Avatar
So what fuel lines and fittings and size and all that good stuff do i need to hook to my stock fuel lines at the rubber line.
Old Mar 16, 2008 | 10:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
https://www.thirdgen.org/forums/alte...ealth-ram.html
I discussed what i did here... more on the exact part numbers at the bottom of the page.
you can hook to your stock rubber lines but i chose to take off the rubber lines and run braided all the way for a cleaner look
Old Mar 16, 2008 | 10:29 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
That link there he gave is great. I unfortunately didnt look at it really till after my swap. I love my hsr now. Im glad i changed things out. It gives you so much more options later on also.
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
L98GTA87
Aug 11, 2015 06:55 PM
