Running 195 stat - PROM tuned for 180. ???
Old Mar 16, 2008 | 03:04 PM
Abubaca's Avatar
Guys,
Had some cooling issues about two years ago, flushed and cleaned the cooling system, and ever since, it's been running really cool. I know the CT gauge isn't really a exact high tech device, but it appeared to never really get over 180-190, and this was with a 180 stat. This seamed OK, and I didn't really question it. Well I just replaced the CTS this weekend, and it's now reading no warmer than about 160. Even when running the car hard, it won't budge more than a degree or two, and then it quickly cools back down.
Would I notice any definite symptoms of the not ever going into a closed loop mode? Should I try a 195 stat? Should I not worry too much about what the stock OE gauge says and not worry about it?
Old Mar 16, 2008 | 06:23 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Running 195 stat - PROM tuned for 180. ???
Borrow a mechanical temp gauge from Bryan
He seems to have plenty of gauges
Once you know exactly how hots its running you can go from there
Old Mar 16, 2008 | 06:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i thought closed loop mode engaged at coolant temps over 104 degrees and once the o2 was hot enough, but i guess that will depend on the prom, not sure if they are different or not.
if you have a 180 stat and the fans are designed to turn on around 180-190 degrees and off at 170-180 degrees, then having a 195 will more than likely keep the fans on alot longer before the tstat ever opens up. NOt really gonna hurt anything i feel
Old Mar 16, 2008 | 06:48 PM
Abubaca's Avatar
I thought it was in the tune, but I'm no expert by any means. I thought that was the issue with running a cooler stat like a 160 with a retune. The computer never entered closed loop. ....but like I said, could be totally wrong.
LOL, that's funny. I doubt any of them work.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
89mulletbird
Aug 12, 2015 07:08 PM
Sanjay
Aug 12, 2015 03:41 PM
