fuel filter
Old Mar 19, 2008 | 09:49 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
fuel filter
changed my fuel filter today and after i got everything hooked up and bolted back together my car hissing from the filter and like steam smoke is coming out also its leaking fuel from the left side. What could be my problem? I thought it was tight because my pliers slip off when I try to tighten it. Any help would be great but im taking it to my mechanic in the morning anyway?
Thanks Guyz in advance
you normally help me with all my problems!
Old Mar 19, 2008 | 10:09 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: fuel filter
sounds like you may have cross threaded it causing it to leak, all you can do is take it back off check the threads on it and the fuel line to make sure theyre not messed up ifso theyll need to be replaced good luck with it,later jimmy
Old Mar 19, 2008 | 10:24 PM
Car: '87 Iroc-Z
Re: fuel filter
Thanks Jimmy, Appreciate it. Anyone else?
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
