the proper cam
Old Sep 2, 2001 | 10:15 PM
FlameRedMetallic's Avatar
the proper cam
hey guys what is a good cam to put in my buddies 86 iroc. it is a stock 305 with stock intake and heads, probably have headers and he already has a cat back. he is looking for a cam to give him good torque, but a little of a rumpity idle. what are some of your opinions?
86 IROC-Z
305 TPI
700R4 W/ shift kit
3.23 gears
T-Tops
maroon with gold stickers and rims/ black interior
43,000 miles
flowmaster exhaust, edelbrock headers, gutted airbox, converter, and MAF, K&N filters.
soon to come are 3.73 gears and subframe connecters.
Old Sep 3, 2001 | 12:42 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Cosdiering he has THE WORST TPI cam ever, a Crane 2030 would be good. It is a 204/214 duration cam with .423/.446 lift. I've been modelling it on Dyno2000 and it along with some WP SR TQer 305 heads. Over 100 hp gained at 5000 rpm. But then again the stock cam only good to 3600-3700 rpm.
Do a search on "Peanut Cam"
.350/.385 lift with 179/194 duration
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Sep 3, 2001 | 11:12 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by Mista:
</font>
OMG the peanut cam is THAT BAD???
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Sep 4, 2001 | 07:41 AM
Mista's Avatar
Car: 1986 Trans Am
No power past 3700 rpm. I have modeled engines on Dyno2000 and with a Crane 2030 cam and World SRT 305 heads, I would gain 100 hp at 5000 rpm. The stock peanut cam is THAT SORRY!
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Sep 4, 2001 | 01:07 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I like my SLP cam Since I have the 87 Block you need a slightly different grind but their part number is 51000 for your 85-86 Engine.
Duration: 258/264 Dur @.050 206/212 Lift 480/487 centerline 112
might want to also consider the SLP pt# for early blocks: 51004
Duration: 270/276 Dur. @ .050: 218/224 lift: 495/502 Centerline 114
I am delighted with my SLP cam.
John
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jorlain
Oct 8, 2015 01:57 AM
webeeZ28
Sep 14, 2015 12:00 PM
TheExaminer
Sep 6, 2015 11:40 PM
masonta
Sep 1, 2015 06:40 PM
