Wild O2/ Overheat Lean
Old Sep 4, 2001 | 04:59 PM
edfirebird's Avatar
I have a MAF 350 Tpi(L89) LT4 HOT CAM , SLP 1 5/8 RUNNERS ,AFPR , DART S/R TORKER HEADS.
THE CAR IS RUNNING SO LEAN THAT IT METS SPARK PLUG BOOTS, SPEEDO CABLE..... THE FUEL PRESS IS 48 (VAC DISC.) BASE TIMING 1 DEGREE. 36 TOTAL ADV. THE TPS IS SET TO .50 IDLE AT 650... iT SURGES. THE O2 GOES FROM .001 TO 1.0 GOING DOWN THE ROAD I THOUGHT IT COULD BE FUEL OR HENCE LACK OF BUT NEW FP. I AM WAY DOWN ON HP .. I HOOKED A SCANNER UP IT SHOWED A 42 EST AND NO VSS. iT MELTED THE CABLE. WHAT ARE SOME POSSIBLE CAUSES MY LEAN CONDITION . ?
:CONFUSED: ED
Old Sep 4, 2001 | 05:02 PM
edfirebird's Avatar
30# SVO INJ, HYPERTECH CHIP, K&N'S 2200 STALL, BAD 700R4, 1LE SHAFT, NEW 02,
Old Sep 4, 2001 | 05:31 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
First off...unlock the capslock key 2ndly welcome to thirdgen.org.
I'd find it hard to believe you're running lean with your setup.
I'd wonder if the melted boots are caused by the headers?
Although your O2 seems real low and real high, what are your crosscounts? What does the BLM value show?
My personal opinion is you have too much injector for your setup, even with a Hypertech chip. If you want to run the 30#er's you may think about heading to the PROM Board and get into tuning.
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Mark_ZZ3
May 24, 2018 01:02 PM
Marc Brown
Sep 28, 2015 01:40 PM
