horsepower from vortec combo
Old Mar 20, 2008 | 04:10 PM
dv013003's Avatar
Car: Firebird Formula 350
Engine: 5.7
What kind of horsepower could I expect to gain if I put a set of vortec heads and intake on a 350 tpi with all the usual bolt on's and free mods available. (ported plenum, afpr, pulleys, tb bypass, maf descreened, CAI, injectors, 1.5 rr's, msd coil, smog delete, high-flow cat, flowmaster, 3.73's, corvette servo, B+M shift kit, LCA's w/ lowering bracket)
I already did searches and havn't really found anything on this question.
Thanks,
Dan
Old Mar 20, 2008 | 10:09 PM
HP junkie's Avatar
Car: 91 Z28
Engine: l98 5.7 TPI
Transmission: 700R4,2600TCI stall,Trans Go
Axle/Gears: 3:73
Re: horsepower from vortec combo
I have vortec heads, base,afpr,ported plenum, large tube runners,cam (218/224 ),Headers, catback, shiftkit ,TC 2600 and 1.5 rr.
My car put down 278 RWHP 317 RWTQ. That was on a mustang dyno.
Old Mar 20, 2008 | 10:14 PM
stealthrocz's Avatar
Car: 87iroc
Engine: 5.7vortecstealthram
Transmission: 5-speed
Axle/Gears: 9-bolt posi
with your combo there, 278hp, on top of that what do you think the holley stealthram would do. 300 maybe 325 ya think.
Old Mar 21, 2008 | 09:02 PM
HP junkie's Avatar
Car: 91 Z28
Engine: l98 5.7 TPI
Axle/Gears: 3:73
The HSR might would push the power band up more. My peak HP was at 4800 RPM's. I'm guessing the HSR would make 300+ HP. My car was dynoed on a mustang dyno. The guy that tuned it said his dyno will dyno 15% less than a dynojet. Then again you really should'nt go by a dyno you should use track times.
Also when I had my car dyno tuned I had the wrong spark plugs in. I was suppose to have the long tapper seat plugs. It was like 2 months later that I stumbled across a thread on this sight about using the wrong plugs on vortec heads. I noticed alot better throttle response after I changed to right plugs.
Old May 2, 2020 | 10:07 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
wrong forum
GeneralDisorder
Dec 19, 2020 12:39 PM
RevItUpZ28
Mar 30, 2006 05:01 PM
turbotater
Feb 22, 2003 02:35 PM
