FIRST TPI build
Old Mar 10, 2020 | 03:53 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Engine: 355, roller, Profilers, FIRST tpi
Transmission: 200r4
FIRST TPI build
Well, its been a while. Car is all sorted out with current engine, transmission. Carbed 355 in front of an Extreme Automatics Stage II 2004R, 2200 stall, 3.42 gears in posi rear end. 2.5 inch exhaust thru Turbo mufflers. Here's where the fun starts. I have a brand new set of Profiler 185 heads, a FIRST TPI, and a roller cam that I am going to install. Car is a 69 Camaro.
Cam specs are:
Intake Exhaust
221 223 duration at .050
280 282 duration at .004
.510 .492
104 112 lobe angle (108 sep angle)
Intake opens 6.5 at .050 Intake closes at 34.5 at .050
Exhaust opens 43.5 at .050 Exhaust closes at -.5 at .050
A lot of cool stuff has come out in the way of efi. I've always liked the look of the TPI. I am thinking somewhere around 420 HP and 500 TQ at the crank. Realistic? I could go another way with EFI or put a carb with annualar discharge boosters on it. Thoughts?
Old Mar 11, 2020 | 05:42 PM
thainglo's Avatar
Re: FIRST TPI build
Have you thought about how the TPI will be controlled? I think the OEM computers like an LSA of 114. I might have the number wrong, but definitely something you'll want to check out.
I have a TPI setup planning to go into my 85 TA and another set I fully polished for my 78 Vette. Have always liked the look, even though the technology is now old.
Old Mar 11, 2020 | 06:34 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
Re: FIRST TPI build
I have an EBL P4 Flash to control it. Got the entire FIRST unit, injectors, computer dizzy, harness, and ECM as a package from a guy. I’m going with a brushed finish plenum, runners that have been powder coated satin black, polished fuel rails, and natural finish base.
Old Mar 12, 2020 | 06:34 AM
ULTM8Z's Avatar
Re: FIRST TPI build
What's your plan for tuning? That combo will need a lot of retuning.
Old Mar 12, 2020 | 07:51 AM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
Re: FIRST TPI build
Yeah, they usually do. In my case, the previous owner sent me all his bins and results of each. Will plug in the one that matches my combo and take it from there.
Old Apr 2, 2020 | 01:47 PM
my hemi's Avatar
Car: A few things lol
Engine: 350 tpi supercharged and a 383 stro
Transmission: Both 700r4s
Axle/Gears: 3.23s and 3.54s
Re: FIRST TPI build
Our car is at the shop now it has a 383 stroker with a first performance intake and tuning is going to be done thru a holley hp efi system hoping she runs good...
Old Apr 2, 2020 | 02:38 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
Re: FIRST TPI build
Nice. I’ve got a 355 with Profiler 180 heads and a Chris Straub grind retro roller. Should make 420 at the crank (conservative guess) and 475 + tq.
Old Apr 2, 2020 | 02:56 PM
my hemi's Avatar
Re: FIRST TPI build
Ours is running a set of 113 vette heads fully ported and polished done by TPIS they flow 250 cfm also using a lpe219 cam by lingenfelter, 1.6 roller rockers, 383 cu in,edelbrock headers, custom y pipe into a mufflex 4.5 in exhaust ,700r4 with a billet pression 9.5 2600 stall convertor.. I have no idea on HP I'm guessing 450 at the flywheel over 500 ft tq..
Old May 3, 2020 | 03:33 PM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: FIRST TPI build
Bolted the the FIRST on a SP383 Deluxe. Used 7730 with Moates Emulator ostrich 2. Tuning took a little while but it's coming along. Used TunerPro RT. Need Dyno session now to dial in SA and WOT AFR for max power. I can feel the Torque waking up at 2500rpm... crazy street car.
Old May 3, 2020 | 04:57 PM
my hemi's Avatar
Re: FIRST TPI build
What cam are you running? Ours is tuned by a holley hp efi system it has a lpe219 cam by lingenfelter we used a set of 113 Corvette heads that flow 250 cfm.. the TB was sent back to Ken at 1st to be ported to his 76 mm TB we run a walbro 255 lph fuel pump and holley 36 lb injectors with a holley dual sync distributor...hoping it performs well we have a built 700r4 with a vigilante 2600 stall convertor with a GM 9 bolt with 3.27 gears..
Old May 3, 2020 | 05:00 PM
my hemi's Avatar
Re: FIRST TPI build
What are these intakes good to rpm wise?
Old May 3, 2020 | 07:15 PM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: FIRST TPI build
Would not know!
its good enough for my set-up
Ken at first performance could tell you
They have 2 intake with different cfm rating
i have the small one
Old May 3, 2020 | 07:18 PM
my hemi's Avatar
Re: FIRST TPI build
Would not know!
yeah i know they flow around 850 cfm to over 1000 cfm with the bigger TB
Old May 3, 2020 | 07:21 PM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: FIRST TPI build
I got a crate engine from GM Performance. I'm no builder
Cam was within specs to match the First intake. I have the 835cfm model. Max duration for that intake was 224
https://www.chevroletperformancestor...e/sp383-deluxe
Walbor 255lph
Bosh III 32lb/hr
OEM HEI distributor
Moser 9inch with 3.90
Tremec 6 speed aftermarket
Old May 3, 2020 | 08:18 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
Re: FIRST TPI build
Erson Roller. 280/282. .510/.492 lift. 108 LSA. 730 ECM with EBL Flash. 355 small block, Pro-Filer 185 heads. Extreme Automatocs Stage 2 2004R, 3.42 10 bolt posi. Global West subframe connectors, Howe tall ball joints, SPC upper and lower control arms. 69 Camaro.
Old May 3, 2020 | 08:27 PM
my hemi's Avatar
Re: FIRST TPI build
Are you running a first performance intake?
Old May 3, 2020 | 11:05 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
Re: FIRST TPI build
Putting one on this summer
stezhead54
Jan 9, 2015 06:54 PM
smokin2002
Dec 5, 2009 04:41 PM
My1986IROC-Z
Dec 1, 2005 05:42 PM
brodyscamaro
Oct 21, 2003 11:48 PM
Black91Z28
Oct 8, 2002 10:21 AM
