stock valve covers with R.R's?
Old Mar 21, 2008 | 07:25 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
can i squeeze a set of roller rockers under the stock covers?
Old Mar 21, 2008 | 07:38 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: stock valve covers with R.R's?
Crane Cams makes 'narrow body' roller rockers that fit under stock TPI valve covers. I ran them for years. There may be other manufacturers producing them also, not sure.
Bill
Old Mar 21, 2008 | 11:55 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
ok i have comp. stainless steel 1.6's im thinking might just work
Old Mar 21, 2008 | 12:24 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
i run 1.6 rollers under a factory gm performance parts valve covers on my lb9 5 speed car... no clearence issues...... i went with jegs brand 1.6 ratio full roller rockers not sure if they are considered narrow bodied but, jegs guys told me they would fit and they surely did only 220$ bux and nice increase in performance for the money cant beat it.
Old Mar 21, 2008 | 07:39 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
You comp pro mags will fit. Just remove the inside baffels and bend the cross bars under the cover vertical rather then the slight horizonal pattern they are at now.
Old Mar 22, 2008 | 12:23 AM
ht4100's Avatar
Car: 86 Z28, 86 Seville, 98 Isuzu Rodeo
Engine: 383, HT4100, & 3.2 V6
Transmission: World Class T-5
Axle/Gears: G92 3.23
I have 1.6 ratio's under stock 86 perimeter bolt valve covers.
Old Mar 22, 2008 | 06:13 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
thanks guys thats some good news!
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
blackd-out z28
Aug 15, 2015 08:18 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
