URGENT!! Where is the EST located?
Car: 1987 GTA
Transmission: 4L60e
Got an 87 350 GTA and need to check the timing before it gets dark here. Where is the EST I need to disconnect located?
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
Well I've got an 89 IROC but maybe they're in the same place...
Mine is on the passenger side at the rear of the engine compartment. It's a single brown wire and it has a connector right there so that you can easily disconnect it.
look right in front of your fan box (passenger side) that is connected to your firewall and the thick wire harness that comes out of your finder follow that for little more than a foot and there will be a 1 wire connector with a brown wire with a black strip on it and that is the EST wire and if you need more help i will send you a pic.
hope that helps
danny
im=firbirdgta
(you beat me to it
[This message has been edited by firbird (edited September 05, 2001).]
hope that helps
danny
im=firbirdgta
(you beat me to it
)[This message has been edited by firbird (edited September 05, 2001).]
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Go to this post for a picture of it.
https://www.thirdgen.org/messgboard/...ML/001499.html
bigjay89gta
Oct 15, 2015 08:04 AM
