TPI Swap
Car: 83 Camaro
Transmission: turbo 350
Axle/Gears: 3:11
TPI Swap
hi im new to this jus picked up a used tpi and wiring harness for my 83 camaro z28 the car right now has a 350 carbd that i built now im gonna fuel in ject it how do u tell if u have a map or maf style tpi id really like to now this im still in highschool and i saved up to build this car will sum1 please help me
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
If it's MAF, it'll have a MAF sensor in the air inlet.
Car: 83 Camaro
Axle/Gears: 3:11
Re: TPI Swap
thats the problem tho i have the harness and the tpi intake outta of ethier an 85 or 86 camaro and it didnt have any of the air box when i took it outt of the car so i was wondering if there was any other ways to identify wich intake i have i can post pics if u would like thank you fo that info tho
Since the factory didn't go to speed density until 1990, it's a pretty safe bet it's MAF if it came off of an '85 or '86.
Since you're asking about TPI-specific issues, and not Engine Swap, let's move this to the TPI forum.
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: TPI Swap
You might also want to check out www.chevythunder.com.
He has a really informative thread on installing TPI in older cars. A lot of wiring schematics also.
Car: 83 Camaro
Axle/Gears: 3:11
Re: TPI Swap
thank you all for the info and the link was very help full i jus have 1 more question can i run this intake with no cold start injector
Sanjay
Aug 12, 2015 03:41 PM
