Which ford 19# injectors can I use?
Subscribe
Mar 23, 2008 | 10:28 PM
I tried searching, but I can't find any specific info on what ford injectors I can use for a stock 305TPI. I found a couple of part numbers, but I'm trying to find out what cars to look for at the junk yard. I think ford 5.0 EFI ones with a yellow top will work, but it appears that there are several different versions. Are the ford injectors a plug and play deal, or do I have to modify anything? Also, I found a decent deal on a set of 19 pounders on ebay, from an 04 4.6L stang. They appear to be skinnier than others though, would these work?
http://cgi.ebay.com/ebaymotors/Ford-...em170203661304
Also, I plan to get an AFPR, so if I got a good deal on a set of 22# or 24# injectors, could I just turn down the fuel pressure, or would I need to update the injector constant in the ECM as well?
EDIT: Also, I'm only looking at using ford injectors because they can be found easily, and cheap. Autozone wants $70 each for new injectors, and a set of Accels is like $270 from summit racing. Are there any other options besides the ford ones?
Reply 0
Mar 25, 2008 | 01:38 AM
Re: Which ford 19# injectors can I use?
Anyone?
Reply 0
Mar 25, 2008 | 07:44 AM
Look for M9593-C302 19#. This has the EV1 connectors you will need.
For more info www.fordracingparts.com
Reply 0
Mar 25, 2008 | 10:40 AM
Are there any factory ones I could pull from the junkyard and use? I know that the Ford 5.0 EFI motors (stang, cougar, etc) got 19 pounders, I just don't know if they will fit, and if the connectors are the same. I see that summit carries the ford racing ones you mentioned, are those a direct fit? I remember reading something about having to modify the clips for them, but I can't seem to find the thread it was in.
Reply 0
Mar 25, 2008 | 11:03 AM
Do an internet search on that number. That should kick up some cross reference numbers and what installed in.
I put the M9593-a302 (24#) in my car used gm o-rings and the clips. no leaks.
Reply 0
Mar 31, 2008 | 02:01 AM
if you run into the problem of the ford injectors being slightly SHORTER you can grind the 4 fuel rail posts down just a bit and they will fit snug
Reply 0
Mar 31, 2008 | 03:51 AM
I picked these up off ebay, I think they will work. They look like they may be slightly shorter, but the bottom o-ring looks to be in the same place. Anyone else running these injectors?
http://cgi.ebay.com/ebaymotors/ws/eB....cWON.m313.lVI
Reply 0
Mar 31, 2008 | 10:01 AM
Lots of the "shorty" injectors are installed without any rail lowering.
Getting the bores clean is #1 to stop leaks. Use carb cleaner. no scratches.
Reply 0
Subscribe
