TH350 Vacuum Supply for Modulator
Old Mar 24, 2008 | 10:51 PM
jimchristiansen's Avatar
Car: Jeeps
Engine: 1970 4 bolt 350, 19000 miles & TPI
Transmission: Tubo 350
Axle/Gears: 4:11
Hello Everyone,
It just occurred to me that with this job nearing completion (does really ever finish: ) that I need another manifold port for my turbo350 modulator. Will the proper vacuum be supplied if I just T off from the map or fuel regulator tpi plenum lines? OR should I T into the brake booster vac from the manifold??
Thanks, Jim
Last edited by jimchristiansen; Mar 24, 2008 at 10:55 PM. Reason: brain malfunction
Old Mar 25, 2008 | 12:59 AM
Car: Jeeps
Axle/Gears: 4:11
Re: TH350 Vacuum Supply for Modulator
Got the answer at:
https://www.thirdgen.org/forums/tran...=modulator+tpi
Pac J
May 17, 2020 10:44 AM
db057
Jan 10, 2020 08:55 PM
FormulasOnly
Jul 23, 2018 08:47 AM
tattmann
Sep 27, 2015 05:20 PM
RedLeader289
Sep 23, 2015 06:50 AM
