Are any of the bases 305 or 350 ok for porting mod?
Hello, I have a 91 L98 and want a spare base to mod and wondered if I need a 91 or 92 350 base only or if the earlier ones or the 305 ones are just as suitable for porting and modifying . PS - Car is not even home yet and trying to modify it! 91 5.7 GTA White with tan leather and all options except T tops and CD, bought north of San Francisco last week and being shipped in an enclosed transporter to Houston , TX area, Everyone keep your fingers crossed for me for no damage. Thanks, Dave
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
305 and 350 TPI intakes are identical, so you can use either one you can get.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
You have speed density!!On earlier models, the have a intake temp sensor on them, yours will not!!!I stuck a 90 TPI base and found this out, also found there is about 3 more holes on a speed density upper intake.
<font face="Verdana, Arial" size="2">Originally posted by davehamilton:
Thanks, Does it matter what year? </font>
Car: Take
Engine: Your
Transmission: Pick
Here is an '85-'86 base w/ the center holes modified to fit BOTH style heads for sale. TPI Base
All you will have to do to make it work is to plug the front hole for the cold start valve switch (very easily done).
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
[This message has been edited by GMTech (edited September 08, 2001).]
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
