Idle Setting
Old Sep 5, 2001 | 04:12 PM
robert1's Avatar
Idle Setting
I just added a BBK 52mm throttle body. It seems there is a "drag" just off idle when running. It takes some effort to overcome the initial throttle movement. Is the gap by the blades too small?
Old Sep 6, 2001 | 11:56 PM
ScreaminDeamin85Z's Avatar
the blades could be geting caught when the throttle is let off. on the TB there should be an adjustment screw to keep it from doing this.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-305 5spd...Jamex Springs...and thats just about it!Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old Sep 8, 2001 | 10:51 PM
Vader's Avatar
R1,
Follow the directions for setting the throttle plate minimum air position and you should solve the problem.
Later,
Vader
"Click - Click - BOOM!"
Adobe Acrobat Reader
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
Andrew6.688
Dec 13, 2015 10:59 AM
bamaboy0323
Sep 3, 2015 06:07 AM
perZ
Aug 15, 2015 01:17 PM
