holley afpr wont lineup to bolt pattern what i do!?
Old Sep 8, 2001 | 02:27 PM
90Iroc-Zee's Avatar
okay, when i went to install it the bolts would not go in. anyone else have a holley afpr and have the same problem? the old afpr bolt pattern is different from the holley. is this crazy or what? and plus i stripped one of the tiny *** bolts and cant find where to get one, think a hardware store has them?
1990 G92 5spd LB9 - 3.42 80,000 miles
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air, Bosch +4 Platinum Plugs
14.4 @ 94mph w/2.0622 60ft (w/o headers and catback)
14.426 @ 96.19mph w/2.167 60ft(w/headers and catback)
Also newly modded w/o track times:
Holley AFPR, Underdrive Pulleys, KYB Shocks and Struts, Crane Ignition
Old Sep 8, 2001 | 03:22 PM
89Irocz23's Avatar
I dunno about that, but if u had to couldnt u plug the holes and drill new holes or something.
Old Sep 8, 2001 | 03:26 PM
kevinc's Avatar
Car: 1982 Z28
My Holley AFPR went right on...try rotating the housing and rechecking the hole alignment, maybe the pattern isn't exactly symetric and the housing has to go on a certain position?
As for a replacement bolt, try your local Sears mini-hardware store. Mine has a huge bolt/screw dept with stuff all the way up to 3/4" Grade 8.
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Sep 8, 2001 | 07:05 PM
poncho9789's Avatar
I have been on an extencive serch for these bolts and after 3 months I have finally given up the bolts are a special size and thread a 5-40 will fit but is too loose and a metric 3 or 4 are not right. the only place to get those bolts are gm. I just drilled and tapped mine for a 6-32 helicoil and got some stainless bolts.
Old Sep 8, 2001 | 08:22 PM
camaroguy99's Avatar
I found them at a local store that specializes in fasteners. It's a 3.5 mm -.6 pitch I think. Plus they are normal phillips heads. How do you like them apples
Old Sep 9, 2001 | 12:44 PM
90Iroc-Zee's Avatar
I'm going and putting the stock one back on. I plan to just use a wrench to fasten that one bolt that is stripped until I can goto the junkyard. I really need my car for school and this was a WAY unexpected turn for the worst.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
