porting edelbrock tpi runners
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Hey all,
i have been working on opening my edelbrock runners and intake to give me a little more flow and to match the larger diameter gaskets (1.75 opening). the problem i am having is reaching the middle portion of the runners. there is a roughly 1.5 to 2 inch portion i cannot get to even with my dremel extension. i can only assume that is giving me a choke point, which is definitely not what i am aiming for. what are you guys doing to get in there? the dremel is slow to work on the inside, but i have been getting what i can with my die grinder, and reaching past that with the dremel. what am i doing wrong here?
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: porting edelbrock tpi runners
Do a search on Standard Abrasives.com lots of info, also at summit.
Engine: 5.7L w/hsr
yeah... that stuff is all about porting heads... i am trying to reach the inside of the runners with the tools they mention. am i just supposed to grind enough material out so that i can reach, or is there a trick i am missing with these long tube runners?
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
