RPM for timing
Old Mar 26, 2008 | 09:55 PM
shuanm's Avatar
Car: 84 Z28
Engine: Stealth Ram 355
Transmission: Borg/Warner T5 WC
RPM for timing
At what RPM should I set base timing?
Old Mar 27, 2008 | 02:33 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: RPM for timing
I set mine at idle, around 800RPM, and it works for me.
Old Mar 27, 2008 | 11:05 PM
shuanm's Avatar
Car: 84 Z28
Re: RPM for timing
My car is very shaky setting the timing at idle. It revs high on startup and takes a long time to settle. Still a lot of rattle and vibration after it settles. Surges from 700 to 1100 a lot. Mainly when I drive part throttle and then let off the pedal.
Old Mar 27, 2008 | 11:08 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Re: RPM for timing
clean out your iac and double check your tps setting
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
