TPI MAP or MAF
Old Mar 22, 2008 | 07:18 PM
Thirdgenracer83's Avatar
Car: 83 Camaro
Transmission: turbo 350
Axle/Gears: 3:11
TPI MAP or MAF
how Do you tell wich 1 u got id like to now cause i jus picked 1 up to swap into my camaro thats carbd right now
Old Mar 22, 2008 | 07:34 PM
CRUSHER's Avatar
Car: 88 Iroc
Engine: 350(300hp G.M crate, supercharged)
Re: TPI MAP or MAF
You have neither.....Those are used on TPI motors......GM used TPI motors on 85 and up.....Your car is carbed not fuel injected....Those items are used on fuel injected motors
On speed density setups you wont have a MAF sensor
On a MAF setup, the MAF is located between the air intake and the throttle body
Old Mar 22, 2008 | 09:17 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
Re: TPI MAP or MAF
From what I got out of that garbled message is that he just got a motor to replace his carbed motor but I may be wrong because the message borders on illegible, a bad combination of abbreviations and misspellings.
You cant miss a MAF, its a large black tubular sensor with wires going into it. It has screens(just like window screen) on each end. If it does'nt have that its probably a Speed Density motor. Do you know what year the motor is? That would answer your question as well.
Old Mar 23, 2008 | 10:39 AM
Car: 83 Camaro
Axle/Gears: 3:11
Re: TPI MAP or MAF
srry i should have been more specific im new to this. i have an 83 camaro it had a crossfireinjection in it when i bought it i changed it all over to carb and built a 350 for it now im goin to change it from carbd to tpi i picked up a tpi and harness out of the junkyard for the car it is ethier and 86 or 85 and i was looking to see if it had a MAF sensor on it but the intake tubing was gone so i was wonderin if ne one could help me find out wat setup i have srry about not posting enough info im still in high school and ive had the car for 3 years ive spent every dolloar ive made on this car and id like to finsh it so please will some 1 help me find a way to identify i can post pics if u want
Old Mar 23, 2008 | 12:28 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Re: TPI MAP or MAF
Chances are that it is a MAF, if it came from a car that old. Speed density cars were made from 90 - 92. Do you have a place for a 9th injector? It is the cold start injector that was used on MAFs I believe.
Old Mar 23, 2008 | 02:55 PM
CRUSHER's Avatar
Car: 88 Iroc
Re: TPI MAP or MAF
Post some pics......
Old Mar 23, 2008 | 04:44 PM
Car: 83 Camaro
Axle/Gears: 3:11
Re: TPI MAP or MAF
heres some picks and i think it does have the cold start injector but it is missing
<a href="http://s74.photobucket.com/albums/i2...23-08_1744.jpg" target="_blank"><img src="http://i74.photobucket.com/albums/i2...23-08_1744.jpg" border="0" alt="Photobucket"></a>
<a href="http://s74.photobucket.com/albums/i2...23-08_1743.jpg" target="_blank"><img src="http://i74.photobucket.com/albums/i2...23-08_1743.jpg" border="0" alt="Photobucket"></a><a href="http://s74.photobucket.com/albums/i2...23-08_1742.jpg" target="_blank"><img src="http://i74.photobucket.com/albums/i2...23-08_1742.jpg" border="0" alt="Photobucket"></a><a href="http://s74.photobucket.com/albums/i2...23-08_1741.jpg" target="_blank"><img src="http://i74.photobucket.com/albums/i2...23-08_1741.jpg" border="0" alt="Photobucket"></a><a href="http://s74.photobucket.com/albums/i2...23-08_1740.jpg" target="_blank"><img src="http://i74.photobucket.com/albums/i2...23-08_1740.jpg" border="0" alt="Photobucket"></a><a href="http://s74.photobucket.com/albums/i2...23-08_1739.jpg" target="_blank"><img src="http://i74.photobucket.com/albums/i2...23-08_1739.jpg" border="0" alt="Photobucket"></a><a href="http://s74.photobucket.com/albums/i2...23-08_1738.jpg" target="_blank"><img src="http://i74.photobucket.com/albums/i2...23-08_1738.jpg" border="0" alt="Photobucket"></a><a href="http://s74.photobucket.com/albums/i2...23-08_1737.jpg" target="_blank"><img src="http://i74.photobucket.com/albums/i2...23-08_1737.jpg" border="0" alt="Photobucket"></a>
Old Mar 24, 2008 | 05:50 PM
Adam 91 GMC TPI's Avatar
Re: TPI MAP or MAF
I think it would be a MAF. I didnt see a MAP sensor on the plenum. If the TPI u got isnt a 90-92 it was a MAF, GM used speed density in 90-92.
Old Mar 24, 2008 | 06:09 PM
Car: 83 Camaro
Axle/Gears: 3:11
Re: TPI MAP or MAF
thank you i look at a couple of pics of other tpi setups and the maf setup looks the closest to mine and looked at wiring diagrams today and the ones for the maf system mached up the closest hopefully this week end ill get it runnin post pics wen done
Old Mar 25, 2008 | 12:56 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: TPI MAP or MAF
It looks like a '85-86 TPI system to me. The lower intake appears to be made for the 90-degree angle center intake bolts used on '86 and older heads.
Old Mar 25, 2008 | 02:34 PM
Car: 83 Camaro
Axle/Gears: 3:11
Re: TPI MAP or MAF
yea it bolted right up to the heads i have on the car wich are off an 86 350 so it probly is an earlier model im hopping it runs is there a difference in computers from different years of the TPI? i would apreaciate this info cause i still need to find a computer for the car and i would like to kno wich 1 i should buy
Old Mar 27, 2008 | 10:04 PM
danielmonster's Avatar
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
Re: TPI MAP or MAF
I'm not sure about the 86 model tpi computer, but I do know the 85 tpi ecm is different than the later years'. Unlike the newer versions, the 85 ecm has 2 connectors that plug directly into the computer rather than 3 and the MAF burn-off relay is piggy-backed on the ecm. Also the PROM (commonly referred to as the "chip") and MEMCAL (fuel calpak) are separate, while in the newer versions they have been combined into one chip. Check out your wiring harness and find out if it has 2 connectors for the ecm or 3 to determine what computer to buy.
Old Mar 28, 2008 | 01:51 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TPI MAP or MAF
The 86-89 ECM uses two connectors also. Its the 90-92 that uses three connectors to the ECM.
NBrehm
Aug 25, 2015 11:49 PM
soarestransam
Aug 24, 2015 08:15 AM
Bert87
Aug 23, 2015 03:50 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
