What can you set base timing to with a "stock" prom?
Old Sep 10, 2001 | 08:04 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Curious what you can raise the base timing to when using a stock prom?
I run a 1987 prom on a modified 5.7L. I changed to a set of MSD wires and I must have moved the distributor some, since the idle is now a bit lower and I can hear the engine searching for an idle sometimes.
My base timing is 8 degrees. I am sure I had 10-12 before.
Opinions?
Mark.
Old Sep 10, 2001 | 09:04 PM
Vader's Avatar
My '86 runs best at about 10° base setting on 93 octane. If I use any lower octane the ESC retard gets excessive and I lose power fast.
Later,
Vader
"Click - Click - BOOM! Saliva - American Outlaw"
Adobe Acrobat Reader
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
djmarch
Aug 11, 2015 10:22 AM
