bad injectors?
Old Mar 27, 2008 | 11:06 PM
leek157's Avatar
Car: 95 SHO. 87 IROC red 69 Vette blue
Engine: 3.0 Yamahammer.5.7 TPI L98, 350
Transmission: mtx4 ,700r4, 4speed,
Axle/Gears: 3.27, 3.73
bad injectors?
i just put all new ignition, plugs wires cap rotor coil mainly because it was in desprete need of a tune up, also the o2 sensor wire was broken so i reconnected that, and a new fuel filter, now the car runs like crap, it idles good but under a load it has no power, i still think its missing somewhere like a plugwire isnt connnected or something , but ive checked those over and over again and theyre all good, so i did a resistance test on all 8 injectors and they were above spec but all close together, and theyre all getting power and opening and closing but can they still be bad, or do i have another problem, ive tried just about everything i can think of and nothing works
Old Mar 28, 2008 | 07:22 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: bad injectors?
Pull some of the plugs back out and see what they tell you.
Old Mar 29, 2008 | 12:58 AM
leek157's Avatar
Re: bad injectors?
ill check it out, the timing and egr are the only things i havent checked egr may be stuck causing a vacuum leak, but i dont think the timing would be off because it was never changed
mike_c
Aug 27, 2015 04:32 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
Bryan F
Aug 18, 2015 02:28 PM
