TPI Loading up
Car: 1986 Iroc Z
Transmission: auto
Axle/Gears: ? dont know much about the car yet
TPI Loading up
Hi everyone, I just bought an 86 Iroc Z 305 TPI. My problem I am having is when they guy I bought the car off of put the motor back in after rebuild he didnt hook up the O2 sensor and it wants to load up very bad. I cant seem to find the wire anyware the goes to it either. I was wondering if it would be possible and if so how difficult it would be to run a new wire from the computer to the O2 sensor. Any help, suggestions, or remedies would be greatly appreciatedThanks
Adam
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TPI Loading up
The stock O2 sensor wiring travels along the driver's side valve cover, down the front of the engine, and then under the driver's motor mount to the gauge temp switch and the O2 sensor. Its a purple wire.
Re: TPI Loading up
It should be in the huge wire loom behind the engine that goes behind the brake booster and into the firewall in that huge plastic plug called the "C100" connector. From there it goes behind the dash and into the ECM.
Car: 1986 Iroc Z
Transmission: auto
Re: TPI Loading up
Thanks for everything guys. I found the wire and I have it hooked up now. Runs much smoother. Thanks Again
Adam
Adam
theshackle
Sep 17, 2020 08:26 AM
Sanjay
Aug 12, 2015 03:41 PM
