Im puttin in a 2nd pump can I turn it on and...............
Old Sep 12, 2001 | 09:35 PM
JucinGTA's Avatar
off with a switch, i would just want to use it for the nitrous. My buddy said that if i have it turned off while driving it might hurt it, is this true????
Old Sep 12, 2001 | 10:23 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I don't see how the fuel would get through the inline pump unless it free-flows or something.
Mine is hooked into the in-tank relay which is at the back of the driver's side back seat, and runs all the time with the in-tank pump.
You want consistent fuel pressure and volume with nos, and I don't see why you just don't hook the pump up to run all the time.
Old Sep 13, 2001 | 01:15 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
unless your gona run a second fuel pickup your gona have to run the pump all the time or your just gona block the fuel line unless you can figure out a way to make the pump freewheel when its not on.
Old Sep 13, 2001 | 01:33 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I am assuming you are speaking of an inline pump like mime. I really don't see any reason why you couldn't shut is off because most of the pumps are free flow pumps. But I also don't really see a reason to turn it off other than to save 8 amps on the charging system. I would just run it all the time provided it is an inline pump. It will take strain off of your in tank pump.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
backtothe80s
Sep 5, 2015 12:39 AM
dhonda200
Aug 11, 2015 11:50 PM
Kaweh
Aug 9, 2015 02:54 PM
