TPI intake swap
Old Sep 12, 2001 | 09:17 PM
NitroMac's Avatar
TPI intake swap
i recently put a 350 crate motor in my 86 which had a carb from the factory. i now want to switch to TPI. will the TPI intake off of a 305 work on my 350? i plan on getting a wiring harness from Painless but what else will i need?
thanks
you can never have too much horsepower
Old Sep 12, 2001 | 10:29 PM
89Irocz23's Avatar
you will need bigger fuel injectors and while the TPI Is out you should port all the intake stuff. Also get bigger runners or just port the old ones.
Old Sep 13, 2001 | 01:29 AM
rezinn's Avatar
Make sure you remember the fuel pump, you need much more pressure than with the carb.
The 305 and 350 intakes are identical except for the injector size.
Old Sep 13, 2001 | 07:50 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
as rezinn said the intakes them selves are the same it's just the injectors are different
305 TPI's have a 19lbs injector
350 TPI's have a 22lbs injector
350 LT1's have a 24lbs injector
a crabed motor runs on about 5 to 9lbs of pressure
a TPI runs on around 42 to 50lbs of pressure so you will need a fuel pump that will handle that kinda presure
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Sep 14, 2001 | 09:44 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Also the knock sensors for a 350 and a 305 are different as well as the chip.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, 16" IROC rims and ASCD SS hood.
future mods:
completely done over suspension, black paint with flames,
T-56 almost ready to go in, TPI swap coming up
Wifes new car:
95Z28, AT, leather, T-tops bone stock for now.
future mods:
header to tailpipe replacement and a cold air intake. Then I am just going to leave it alone
Old Sep 14, 2001 | 01:23 PM
Ehelmsin's Avatar
Get yourself a book called "TPI swappers guide" it will tell you everything you need to know.
1992rs/ss
Jan 31, 2025 05:10 PM
Fast355
Dec 2, 2016 06:33 PM
masonta
Aug 31, 2015 10:14 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
