O2 sensor and ECM ?
Old Sep 15, 2001 | 07:13 PM
JETHROIROC's Avatar
O2 sensor and ECM ?
I have been chasing a rough running/stalling/low idle/lack of power problem for many moons now. I decided to disconnect the O2 sensor and run the car for awhile, and even after the car got hot as hell (and should have been checking O2 output), the ECM never set the service engine soon light. The light works fine, even after several starts and stops and extended idle periods the lack of an O2 sensor never set a code. My question is, shouldn't this flash the SES light? If so, then am I due a new ECM? Thanks guys.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Sep 15, 2001 | 07:23 PM
JETHROIROC's Avatar
Also, if it matters, I never drove it, just ran it at idle and revved the engine slowly up to 3000 RPM and back down, holding it at various speeds in between for extended periods of time. I'm sure with the car being hot enough for the engine fans to come on the O2 sensor should be referenced by the ECM. What gives? Thanks guys.
gta892000
Aug 11, 2019 11:16 AM
skeltor
Feb 2, 2016 10:37 AM
customblackbird
Oct 1, 2015 04:30 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
willyjoejr
Sep 3, 2015 09:26 AM
