how easy is it to convert from maf to sd
Old Sep 16, 2001 | 12:45 AM
poncho9789's Avatar
I know that I will probally have to change to sd ecm a wiring harness and I have a tpis bigmouth intake is the map sensor mounted to it or to the plenum? has anyone done this I would love to hear that it was easy.but bring on the horror stories.
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit,2800 converter, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,holly afpr,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil,150 shot NO2. This car is currently under rebuild and restoration.
Old Sep 16, 2001 | 05:02 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am doing a MAF to SD conversion right now.
As far as I know, all you need is the new ECM, Prom, Map sensor, Knock sensor I think, and wire the MAF harness to the SD computer.
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Sep 16, 2001 | 07:18 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Here's a link I used to do my swap.
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Sep 16, 2001 | 02:21 PM
camaro89RS's Avatar
I went form TBI to TPI SD and it really wasn't that hard. I went to SD because I go the tpi set up from a 85 iroc, and I was told that the ecm and wiring harness from that year was junk, so I was getting a new wiring harness any way. I already had a MAP sensor from the TBI and my buddy from TPIS, and the local junk yard got me everything else that I need, which Zepher already told you pretty much all you need.
Jason
Old Sep 16, 2001 | 10:47 PM
leirch's Avatar
Just go right to Mike Davis's site that John has already provided. That is ALL you need. I used it along with many others. I used to to make an 85MAF--->SD harness for my dads S10. Its great.
Many thanks to Mike for all of the hard work!
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Sep 16, 2001 | 10:49 PM
leirch's Avatar
If you'd like to see what my harness looks like go to my page in my signature and check out picture 27.
Brendan
[This message has been edited by leirch (edited September 16, 2001).]
GTAman
Sep 21, 2015 09:57 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
z28guy134
Sep 1, 2015 11:50 PM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
