Starts fine then dies after 5 mins
Old Apr 1, 2008 | 08:06 AM
pa_richardson's Avatar
I have had this problem for a while and whilst trying to fix it by changing
sensors such as Coolant sensor, Iac, Map, ecu, Plugs, ignition control etc i started seeing another problem with it smoking really badly i finaly found a broken wire on the knock sensor.
But the same old problem returned with it stalling after a perfect start up after 5 mins.
After that it wont start if i unplug injectors i can get it running but it runs really bad with lots of smoke...
Once cooled down it will start again and again after 5 mins it stall..
When trying to start the engine after it has stalled it seems to turn over slowly even though the battery is new and charged
Any Ideas please..
Old May 26, 2008 | 04:52 PM
Re: Starts fine then dies after 5 mins
Okay i sorted it i was looking in wrong place turned out to be the pick up coil once changed the smoke went away and engine runs better than ever...
Thanks for all you help
Old May 27, 2008 | 10:10 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
That happened to me once. It was really cold out and I was just sitting the driveway waiting for my brother to grab his stuff and get in and all of a sudden it just stopped running after about 10 minutes. Could that just be because it was cold? It has only happened that one time.
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Wade787b
Sep 29, 2015 01:15 PM
backtothe80s
Sep 5, 2015 12:39 AM
Bryan F
Aug 18, 2015 02:28 PM
