305 injectors for 350
i recently did an engine swap 305 to 350 the mechanic used the original 305 injectors to feed the 350 would those injectors be adequate and what fuel pressure will i have to adjust my regulator also my ecu has a 350 prom installed with the changeover
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by pontiacpete:
i recently did an engine swap 305 to 350 the mechanic used the original 305 injectors to feed the 350 would those injectors be adequate and what fuel pressure will i have to adjust my regulator also my ecu has a 350 prom installed with the changeover </font>
If it is MAF, you can run with a 305 eprom as MAF is "not concerned" with displacement - so the 305 eprom will have the proper sized injectors. But with SD, the ecm must know both the displacement and injector size. In that case, you cannot just swap a 305 or 350 eprom. You must make the eprom know the displacement and injector flow.
On a positive note, most GM calibrations tend to be overly rich and adjusting fuel pressure has its greatest effect @ WOT and least effect @ part throttle. At part throttle, the O2 sensor will self correct (to a point). So just bump up the fuel pressure and it should be okay(ish). But burning an eprom is the best route.
Car: Death Mobile
Engine: 666 c.i.
Just run a 305 eprom for your MAF car and all will be fine with the stock 305 injectors.
If your run 24# injectors you will need a custom eprom for optimal performance.
