To cam or not to cam? Siamese base.
Old Sep 20, 2001 | 07:19 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Two questions. Do I have to remove the valve covers to remove/install the manifold base? Also, I have a 305 TPI with the L98 cam(stock), 5 speed, edelbrock headers, 160* stat. I plan to siamese the base, but should I also install the crane 2032 cam 214/220 (I have)at the same time? I plan to burn a new PROM. Just wondering if anyone thinks I'll feel a nice difference with just the siamesed base w/o the work of installing a cam?
Old Sep 21, 2001 | 01:27 AM
poncho9789's Avatar
you should notice quite a bit of power increace with those 2 mods togeather as long as you have ported the plenum to match. You will need some good heads or port your heads when you get a chance. Porting the heads will allow you to pass that extra air into the cylinders.
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Randomtask2
Sep 10, 2015 08:37 AM
masonta
Sep 1, 2015 06:40 PM
