need vacume line help please!!!!!!!!!!!!!!
Old Sep 21, 2001 | 12:42 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
im doing my EGR and i have some vacume lines that i have no idea where they go. There is a vacume port or distributor (not sure whaat to call it) on the passenger side of the engine right behind the last injector on that side. it has 2 vacume lines comming off of it. the back line is the shorter one and it goes to the EGR. the front line is much longer and it was not hooked to anything when i pulled the plenum. there was also a rubber T with a short piece of vacume line that has a 90 degree bend in it sitting on the top of intake, just laying there. any idea where these go to???? please help. thanks a ton
Old Sep 21, 2001 | 01:12 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
The longer vacuum line from the 2 port fitting near the back of the motor connects to a vacuum port on the bottom of the throttle body.The other line laying on top of the motor sounds like the line that goes from the plenum next to the big vacuum port to the fuel pressure regulator if i remember my T/A correctly.
1982 Z28:355,4 Speed,Lots of bolt ons
[This message has been edited by onebad82z (edited September 21, 2001).]
Old Sep 21, 2001 | 01:15 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Hey man,
That's the EGR soleniod you are talking about. That should go under the plenum, to a T on a fitting on the bottom of the Throttle body, and over to the canister. Here's a link with the complete vaccum lines diagram:
http://www.chevythunder.com/fuel%20i...um%20lines.htm
That should show you what I am talking about, good luck! If you still need some help post back or better to email me as I can get forgetful at checking back.
eds11979@hotmail.com
Old Sep 21, 2001 | 09:02 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
While we're on the subject, what do the guys that run breathers do - do they just remove the connections to the TB and/or PCV valve...? I've always wondered.
thanks,
Ken
1986 IROC-Z Conv't
17x9.5 TT II's w/ 275/40x17's, BMR stb, Lakewood APR, Jamex 1.5" Lowering Springs
ChevyKen's Cars
Administrator @ ChevyWorld.net
Old Sep 22, 2001 | 12:55 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
ES87iroc- i sent ya an email, did u get it????
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
