Oxygen Sensor Question
Old Sep 21, 2001 | 01:13 PM
Justin Moore's Avatar
Car: 1986 Z28
What color is the wire going to the oxygen sensor on an 87 Camaro. It is an Iroc with a 5.7L V8.
Old Sep 21, 2001 | 06:45 PM
mckenzie's Avatar
i believe the wire is purple. best of luck, tom
86 iroc 305tpi auto. mild cam
Old Sep 21, 2001 | 08:42 PM
rezinn's Avatar
its pink
Old Sep 21, 2001 | 10:10 PM
breathment's Avatar
PINK?? are u sure? was lookign at mine today and it looked black, maybe its dirty
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 22, 2001 | 07:27 PM
JETHROIROC's Avatar
Pigtail is black or purple. I think the wire to the ECM is pink or purple. Hope this helps.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Sep 22, 2001 | 11:17 PM
IROC&ROLL
Guest
Posts: n/a
The wire should be purple, but often looks black near the sensor due to heat discolorization.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beast94
Aug 20, 2015 06:44 AM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
