Those running the LT4 Hotcam
What should valve lash be set at with 1.6 full rollers? With S/R torquer heads and stock 350 block would it be safe to say I will have enough piston clearance?
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I went with 1/2 turn (just the nut) plus another 1/8 turn with both the nut and lock. I've heard anywhere from 1/4 turn to a full turn is OK. You should have plenty of clearance. My 355 is zero-decked (stock is ~.025") and slightly-domed pistons and am running the same cam and 1.6 CompCams Pro Magnum rockers and still have enough clearance. My only problem is that this gave me over 11:1 compression, so I can't run more than 26 degrees of timing at WOT w/out running 104 octane race gas. :/
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i adjusted mine so that the pushrod had enough tension on it to keep it from spinning and then another 1/2 turn.
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
car has found a new home
she will be relocating soon,thanx to all that were interested and the few who had purchased some of the many,many extra parts i had accumulated over the years.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
best e/t:
1988iroc350tpi
Aug 14, 2015 07:52 PM
