Setting the timing (where is the distributor bolt?)
Old Apr 11, 2008 | 03:42 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
I can't seem to find it.
Can anybody show me where to look?
Old Apr 11, 2008 | 03:51 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Re: Setting the timing (where is the distributor bolt?)
if you look at the base of the distributer, there is a bolt that is holding down a plate that is leaning on the distributer shaft. standing at the nose of the car, its exactly to the left of the distributer... that is the bolt they are referring to. loosen that up until you can move the distributer by hand and proceed with your timing changes.
i dug through my pile and found a pic
Old Apr 11, 2008 | 04:49 PM
Car: 1989 GTA
Originally Posted by Reid Fleming
Well it appears to be that bolt below that spring down there. Managed to bust the spring off. But couldn't get a bendable box end wrench on the bolt. The darn bracket from the coil blocks access.
Gonna have to take the coil bracket apart to get access to the bolt. Why is car stuff never easy?
Old Apr 11, 2008 | 04:57 PM
thunder85's Avatar
Engine: 5.7L w/hsr
actually, they make a wrench specifically for doing this... its only 5 bucks and makes life very easy. http://www.autozone.com/R,NONAPP3454...ductDetail.htm
this crap is never like those tv shows... i just got my whole tpi setup rebuilt and ready to go, and found out that 2 or 3 of my injectors stuck open after the first 20 minutes of running... so i gotta tear the damn thing back apart, replace the injectors, and try again. don't see that on Horsepower tv. those dudes never get dirty either... freakin amazing
Old Apr 12, 2008 | 01:01 AM
Car: 1989 GTA
I owe you a beer after seeing the link to that $5 wrench. Especially after I just dropped $70 on a set of bendable open end wrenches. (Granted they are nice).
I wholeheartedly agree with you about those TV shows. And isn't it amazing how many "old spare parts" they have kicking around their garages? "We had this 12 bolt rear end and cross ram setup sitting in the corner. So we thought we'd put it to use for our '69 Camaro buildup." Uh huh. Sure.
Even seeing your picture, it definitely showed me where the bolt was. But it looks so much easier to find in your car. Seemingly simple things like this make me miss my old Sunbird. Distributor was in the front of the engine. No AIR hoses or lines to get in the way of setting the timing or changing plugs. The thermostat in that car was underneath the radiator cap. Simplicity at it's finest.
Old Apr 12, 2008 | 07:42 AM
thunder85's Avatar
Engine: 5.7L w/hsr
lol... mine appears easier because what you don't see is my entire tpi setup in a pile on the ground next to the car... that and my coil is off, and that egr selenoid is just laying there. that intake got yanked and replaced with an edelbrock intake, edlebrock runners, etc. but even with everything on, it is fairly easy to get that wrench onto that bolt to do the timing adjustments.
Old Apr 12, 2008 | 09:42 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
HP TV
They dropped the front frame to pull the motor, car/body was hoisted up off the front suspension/engine assembly. During the reinstall the guy talking said his buddy hooked up all the wires/connectors, and had a little challenge with it. Oh yea, that was last week, and took all week, but they didn't tell/show you that.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
red90IROCls1
Aug 25, 2015 06:56 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
