what temp does engine come out of open loop?
Old Sep 25, 2001 | 10:55 PM
breathment's Avatar
im just curious when the engine comes out of open loop? i thought it was when the engine was 158* and the O2 sensor was above 600*. i don't need any in depth explination, cause i have a TPI book that explains open loop vs closed loop, but i don't think it has the temps, so if ya could plz tell me.
thanks.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 25, 2001 | 10:56 PM
robert1's Avatar
I was going to say 160 and 600, so it sounds right to me too.
Old Sep 25, 2001 | 10:59 PM
whiteroc's Avatar
I had my car hooked up to a Tech 1 this morning -it went into closed loop at about 158* & from what I remember the 02 needs to be over 660* also.
[This message has been edited by whiteroc (edited September 25, 2001).]
Old Sep 26, 2001 | 06:36 AM
Vader's Avatar
AUM/BUA Closed-Loop Operation Parameters
CTS < 14.7°C (58°F) for 75 seconds;
CTS >14.7° (58°F) and < 40.7° (105°F) for 51.4 seconds;
CTS >40.7°C (105°F) for 12.5 seconds;
O2 >0.699V & O2<1.99V for 10 seconds;
Coolant Temperature Sensor Related Parameters
BLM enabled between 50°C (122°F) and 140°C (284°F)
Cold spark advance disabled above 56°C (133°F)
Hot spark retard begins above 116°C (240°F)
Highway Mode spark advance > 59.8°C (140°F)
Knock sensor disabled below 66.5°C (152°F)
Power enrichment at base A/F ratios > 56°C (133°F)
Target IAC idle RPM >80°C (176°F)
IAC multiplier at 1.0 (base) > 32°C (90°F)
Knock Control enabled > 67°C (153°F)
EGR Duty-cycle enabled at 56°C (133°F)
EGR Duty-cycle at MAX >80°C (176°F)
TCC lockup enabled >50°C (122°F)
SHIFT light enabled >50°C (122°F)
Diagnostic communication enabled at 70°C (157°F)
DTC 43 enabled > 90°C (194°F)
Cooling fan #1 enabled at 107°C (226°F)
Cooling fan #1 off at 104.7°C (220.5°F)
Cooling fan #2 enabled at 115.2°C (239.5°F)
Cooling fan #2 off at 110°C (230°F)
Cooling fan duty cycle at 100% at 80°C (176°F)
Acceleration enrichment multiplier at 1.00 below 80° C (176°F)
Acceleration enrichment multiplier at 0.75 above 80° C (176°F)
Acceleration enrichment multiplier at 0.50 above 104°C (220°F)
Acceleration enrichment decay factor at 25% below 80° C (176°F)
Acceleration enrichment decay factor at 40% above 80° C (176°F)
Acceleration enrichment decay factor at 50% above 104° C (220°F)
Acceleration enrichment decay factor at 60% above 128° C (262°F)
Fuel limiting factor timer at 217 counts below 80° C (176°F)
Fuel limiting factor timer at 169 counts above 80° C (176°F)
Code 13 (oxygen sensor fault) enabled above 70°C (157°F)
Code 14 (CTS high fault) enabled above 130°C (266°F)
Code 32 (EGR fault) enabled above 30.5°C (87°F)
EVAP canister purge enabled above 70.3°C (158.5°F)
Hot closed-loop timer enabled above 70.3°C (158.5°F)
Rich/Lean O2 offest at 16 counts between 20°C (68°F) and 92°C (197.5°F)
A/C clutch disabled above 150°C (302°F)
Miscellaneous
25.3° maximum allowable knock retard when not in WOT
Later,
Vader
Justice and Freedom will Prevail
Old Sep 26, 2001 | 11:11 AM
nblanchard's Avatar
Wow... where did you get all that information... thats like the bsckbone of the ECM... impressive
Old Sep 26, 2001 | 04:02 PM
breathment's Avatar
showoff
- David
88' GTA 5.7L TPI MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
italiano67
Dec 11, 2016 09:21 AM
Jae992
Aug 27, 2015 09:07 AM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
