91 305 tpi need help no power.
Old Sep 26, 2001 | 06:06 PM
91ta-ragtop's Avatar
91 ta 305 tpi auto about 50% of the time car has no power at all when trying to accelerate always starts and idles fine if I turn ignition off then restart it will then run fine sometimes I have to turn off and on several times then runs fine there doesnt seem to be any pattern no fault codes from ecm tpi checks good ignition module checks good thanks for any help also installed fuel filter and pcv valve.
Old Sep 26, 2001 | 06:46 PM
kevinc's Avatar
Car: 1982 Z28
Yeesh...was that all one sentence?
Gonna need to get a scantool on it and grab some data, one session while it's running good and another while it's running bad. If you have access to a laptop you can use Craig Moates' software and an Andrew Mattei cable (Craig is free, Mattei gets $60 or so for a cable) for this.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
