Name that part!
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Name that part!
How much more vague could I be?
Ok, so there is a vacuum (?) line that comes off the tpi plenum at the passenger side rear (just forward of that MAP sensor) that runs into a 1-2" long, cone shaped plastic piece that t's off. One rubber line from the "T" goes to the evap canistor, I think. And the other small dia plastic line from the other side of the "T" runs into through the firewall.
While I was mucking with a heater core hose, one of the "T" off lines snapped off.
I think the 3-way plastic piece is a vacuum valve. I dont know what its called and I need the name of it. I think its a vacuum piece with a one-way check valve.
Can I just get a new generic plastic "T" valve or is it important to get an exact OEM part? If so, anyone have the part number?
Car: 1990 Camaro RS
Engine: L03 305 TBI
Re: Name that part!
Sounds like you're describing the check valve to me. You can find them at advance auto parts that I know of, and most likely any other half-way decent auto parts store. Advance had them out in the isles when my friend and I went to get one for his.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Name that part!
That's the HVAC/CC valve. It goes between plenum vacuum, cruise control supply vacuum, and your heater supply vacuum. You need it. I got mine from the stealership.
Re: Name that part!
yeah I couldnt find it at advance. But Ill check the dealership. Thanks for the part name.
LT1Formula
20
Nov 14, 2015 12:02 AM
