Miniram w/ aftermarket heads??
what are some good heads to put on a
350 w/ a miniram on top,LT4 "hot cam",DFI,SVO 24# injectors,.
what are some aluminum heads that would match up to a 85% street car that i want to run low 12's in the next 1 1/2 years.
TIA,
RS
(A.K.A FireBird88)
AOL SN: Zander0710
1992 Camaro RS 25th anniversary edition Adopted Feb,14 2000
Mods:
14x3 Open element w/ K&N filter, MSD GM blaster Coil and 8.5 SC wires, AFPR, 60psi. Fuel Pressure gauge, 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
TIA,
RS
(A.K.A FireBird88)
AOL SN: Zander0710
Mods:
I would go with the AFR 195 heads.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
The Trick Flow 23-degree heads are cheaper and flow almost as good (or nearly the same) as the AFR's, but are several hundred dollars cheaper. GM HTP mag tested several heads recently, but they used the ones w/out the CNC ported combustion chambers. These heads are fully emissions legal (EGR ports, etc.) and have angled plugs for better spark plug access with headers. You can get them with 1.25" or 1.47" springs that can handle .520" or .540" lift, respectively. Just MHO...
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Engine: 385 HSR
Sure they'd work, but not as good as the Trick Flow or AFR heads. They have much-smaller intake ports and flow a good bit less air. You could have them ported out to match the other heads, but then you'd end up spending more money than if you just bought the TF or AFR heads...
Greg Westphal
'87 IROC 355TPI/A4
Greg Westphal
'87 IROC 355TPI/A4
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Im running the Tick Flow 23* heads with my Mini-ram and ZZ9 cam. I wish I went with one of Comp Cams grinds. I think the ZZ9 is a little small for my set-up. Plus it was like 100 bucks more. Oh well....live and learn.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.6/1.52 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, Accel 300+ box & coil, Taylor 409 wires, Fastchips custom chip, MAC sub frame connecters, Lakewood LCA & Adj. Panhard rod, SLP 2500 stall, 3.42 rear gears, 1LE aluminum driveshaft, white face gagues, and NOS!
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Trick flow heads are trash. They don't even have bronze valve guides! Sure they flow the number, but they won't do it for very long. I have heard lots of nightmares about the Trick Flows. AFR 190's are the same as the 195's, they flow the same, look the same, same components. 195's are just matched to the victor Jr. intake. I don't know what the intake runner on the miniram is, but I'd go with the 190's if you have the money.
Personally, I didn't have the money, so I went with the Dart Iron Eagles. My reason being that with the expansion rate of cast iron and aluminum, there are sometimes sealing problems. Also, it is much easier to warp aluminum if your car gets a little too hot while driving on the steet. Aluminum threads can strip out much easier. There are also compression ratio issues because aluminum disapates heat faster than cast iron, which is why many people subtract a point from the static compression ratio with aluminum heads. This makes the science of compression ratio calculation a little more sketchy.
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Flowmaster Exhaust
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I'm running a 383 with AFR 190's and a MiniRam. Great combination. Two weeks ago I ran 11.61@117.5 on street tires and full exhaust including cats!
www.geocities.com/dzperf
D&Z Performance
"Putting Power to the Pavement"
D&Z Performance
Since your using just a 350, I would go with the AFR 190s, not 195s. The 195s would probably shift the power band too high for the displacement you have. You could also look at the 180s and just have them ported out, it will give you more low end.
L98 TPI 350 (5.7L)
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
L98 TPI 350 (5.7L)
LT1Formula
20
Nov 14, 2015 12:02 AM
TRAXION
Aftermarket Product Review
87
Nov 22, 2008 10:33 PM
Steve91Z28 L98
20
Jun 7, 2001 07:53 AM
