no2 through the injectors
Old Apr 14, 2008 | 09:04 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I have an idea brewin
can it be done
Old Apr 14, 2008 | 11:24 AM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Re: no2 through the injectors
yeah... kinda. its called direct port nitrous injection.
Old Apr 14, 2008 | 12:02 PM
s24a's Avatar
can it be done
If you mean using injectors to introduce Nitrous, then technically , Yes.
But they will wear out quickly due to being dry, as the nitrous, unlike the liquid fuel, does not cushion the needle/seat interface like gasoline.
better to do like Thunder85 suggests.....
Old Apr 14, 2008 | 02:58 PM
DAKMOR's Avatar
Does nitrous spray dry all the time?
As in, what if you let out 1/10000th of what you would when you use it during everyday use? Would that help? I got a funky idea brewing too,
Old Apr 15, 2008 | 09:19 AM
jamon8's Avatar
Engine: 350 tpi
can I run fuel into the rail and then meter the no2 into the rail and spit it into the injector
Old Apr 15, 2008 | 09:49 AM
thunder85's Avatar
Engine: 5.7L w/hsr
i wouldn't think so. the nitrous is a much higher pressure system (in order to maintain liquid form), and introduced into the comparitively low pressure fuel system rail would cause it to revert to a gas in the fuel rail, cause excessive pressure buildup, and i assume all sorts of interesting problems. thats why no matter what system you have, the fuel and nitrous hydraulic circuits are always seperate until the point of injection
Old Apr 15, 2008 | 11:25 AM
s24a's Avatar
That would most likely cause all kinds of issues, from maldistribution of the NO2 cylinder-to-cylinder, and potential for explosions, since the NO2 carries its own oxygen (that's why it works), and the lean condition caused by the displacement of the fuel by the NO2 gas....remember, NO2 needs MORE fuel to utilize with the oxygen in the nitrous....
If you want a PWM (kind of) solution, you could use a cold start injector and feed NO2 using it. You can PWM these things, but only grossly. So you still need to have a nitrous limited orifice upstream for flow control.
Old Apr 15, 2008 | 11:50 AM
thunder85's Avatar
Engine: 5.7L w/hsr
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
