Does my ecm need programming?
Old Apr 15, 2008 | 02:59 PM
pa_richardson's Avatar
I removed the AIR system, Smog Pump and Blocked EGR.
Now the engine runs to rich, smokes and is undriveable.
Does the ECM need reprogramming due to the different vacum set up due to AIR being removed?
Should the emmisions input pipe be left open or be blocked wich is the pipe just behind the TPS sensor at front of the throttle body.
Hope you guys can help this problem is driving me mad...
Old Apr 15, 2008 | 03:19 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Re: Does my ecm need programming?
http://www.autozone.com/images/cds/g...3d8016381e.gif
the evap canister didn't need to be removed... you have vacuum leaks and have messed up your tank vent circuit. plug the vacuum line that went to the egr selenoid. re assemble the evap canister/fuel tank pressure system (the lower of the 2 ports behind the tps sensor is what goes to this) and yes, having pulled your egr off will require you have an upgraded prom.
when you pulled your tpi system off to strip the egr, did you use new gaskets? if not, there's a good chance you have some vacuum leaks between the runners and the plenum/manifold.
and on a side note the air rig has nothing to do with your vacuum system
Old Apr 17, 2008 | 03:43 PM
Hi thanks fo the reply i have been looking for an answer to this problem for a long time and this seems like the answer i have noticed a pipe coming up from the tank but cant remember pulling that off, the tpi is in a astro van and the tank is the astro tank...I will check this soon.
Old Apr 19, 2008 | 07:59 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
The tank vent circuit is fine. You don't need the evap canister. It doesn't hurt to have though.
You don't even need the solenoid. Just vent the hard line coming from the tank to atmosphere inside your fender.
Removing EGR does require minor programming to disable it from the prom.
Just plug the port on the TB.
Definitely look for vacuum leaks.
Removing the AIR system does not require any programming.
Old Apr 19, 2008 | 10:42 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Have you hooked up the O2 yet???????
Old Apr 19, 2008 | 04:03 PM
Okay i checked the petrol tank and apart from the main line and return line there is a third line running up to the front it has never been connected.
I have not connected a O2 sensor up yet as this problem is from cold and it has never been connected and does not show any error codes related to the 02.
I did block the pipe going to the TB it slows the idle down when its blocked.
Its funny that when the engine is running and its puffing out smoke if you disconnect the MAP the engine changes completly and stops smoking yet will not rev properly.
I have posted a few helps for this problem.
What can be the problem why does it run so so rich and flood itself if you let it stall.
I am no mechanic but have checked and read for weeks about tpi's.
Ive changed items such as ECM,MAP,IAC,Ignition module,Dis cap, rotor arm,plugs, leads,Temp sensor, Checked every wire and plug, new fuel, new oil, new battery, new grounds on engine, Checked injectors and had cleaned, cleaned out TB added a fuel regulator, checked fuel pressure, etc
Im Trying...
Could it be the MAT or maybe a faulty chip?
Once the engine is dried out from flooding it will start and idle, It puffs smoke out with a fuel smell, It revs like its missing on some cylinders, and will stall if you let it idle to long at this point it will not start untill you unflood it by unplugging fuel relay or injectors or clean all plugs.
Thanks all help guys i hope you feel my pain...
Old May 26, 2008 | 04:49 PM
Okay i sorted it i was looking in wrong place turned out to be the pick up coil once changed the smoke went away and engine runs better than ever...
Thanks for all you help
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
