Is there plug to header(SLP headers)interference on Edelbrock 6085 heads?
Old Sep 30, 2001 | 06:44 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
I believe the Edelbrock 6085 heads are straight plug heads and wanted to know if there would be any problems with plugs interfering with SLP 1 5/8" headers?
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
160 degree thermostat
Rebuilt 700R4(borg warner/raybestos clutches,Kevlar band,vette servo)
B&M 2400 stall torque converter
Paxton SN92
Old Sep 30, 2001 | 07:20 PM
james_fearn's Avatar
That's what I have. Clearance is only close on one plug but there is still more than enough room. The clearance problem is more of a problem when installing the plug rather than when they are installed. I am running 90* MSD heli-core wires and no heat/header related problems.
James
1985 Z-28, 350 TPI, T-Tops, edelbrock 6085 heads, ZZ4 cam, accel base/runners & 24 lb/hr inj., ported plenum, everything gasket matched, crane AFPR, SLP 1 5/8 headers, single 3" flowmaster catback, 3" Catco cat, modified tranny, 165 ECM & ARAP code, MSD 6AL/wires, edelbrock STB, Spohn SFC/LCA/PR, GW "wonderbar"
Old Sep 30, 2001 | 07:49 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Yes, they will fit, but like James mentioned getting the plugs in and out can be interesting. Be prepared to "customize" your spark plug socket. I had to find one that had a hex pattern on one end so that you can get a wrench on it, and then cut the length of it down by about half. This is the only way to get it on the spark plug since the headers are so close. But other than that it's not hard.
Black 88 GTA L98
261 RWHP, 345 RWTQ
13.406 @ 103.72 MPH
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back, Stock PROM
E.T.F.A Member #11
Old Sep 30, 2001 | 07:56 PM
Mike89GTA's Avatar
No interference when they're in, the hard part is changing them. Plugs 5 and 6 are the hard ones, for 6 I had to unbolt the headers and lower the spark plug down on a piece of dental floss then pull the dental floss (which was wrapped around the plug) to spin it into the head. I have 1 3/4 ones though so maybe there's less room, plus the AIR tubes are a total pain, if you don't have those it's a lot easier. The rest of the plugs are extremely easy to change though.
4 bolt 350, 10.4:1 Compression, Edelbrock Aluminum Heads 6085, LT4 Hot Cam /w 1.6 full rollers (Crane), Scat Crank, SLP 1 3/4" Headers, SLP Cold Air Intake, Crane AFPR, 48mm TB, ported plenum, stock runners, Accel Super Ram intake manifold, 95Z #24 injectors, stock fuel rails, T5 Tranny, 3.45s, 9 bolt rear, 4 wheel discs, BFG Comp T/As rear, SZ50s in front, Alston SFCs, ES Trans Mount, ES front A-arm bushings, ES front sway bar end links
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
evilstuie
Feb 28, 2016 03:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Reddeath210
Oct 6, 2015 08:20 AM
Zeek1041
Aug 21, 2015 08:45 PM
