takes 10-15secs. to turn over
Old Apr 15, 2008 | 06:47 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
i recently replaced my fuel pump, sending unit, and maf sensor on my 305tpi.
just yesterday i began having the exact same problem i had before i replaced the fuel pump. the car cranks and then takes 15sec to sputter and turn over. wat should i check now?
Old Apr 15, 2008 | 08:02 PM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Re: takes 10-15secs. to turn over
Timing?
Old Apr 16, 2008 | 01:36 AM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
You may want to check and see if the cold start injector is working correctly.
Old Apr 16, 2008 | 01:55 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Have you checked if you got spark ? have you checked if your injectors working ? Do they got an inj.pulse while cranking ? Do you have fuelpressure ?
Old Apr 16, 2008 | 04:54 AM
Car: 1986 IROC-Z28
thanx alot guys how do i check the cold start injector? that theory makes sense, because the problem only happens after the car has been sitting for more than about 4-6hrs.
Old Apr 16, 2008 | 01:31 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
i had that problem for the longest time with my tpi 350... i replaced almost all sensors, fuel pump, etc. my injectors were recieving the pulse, had correct resistance, but apparently weren't working quite right. had a slightly rough idle (just the hint of a skip) hard cold starts, etc. i changed my injectors out for new ones... and problems all went away. smooth idle... no more hunting rpm.. starts within a couple seconds, etc. i got bosche type III injectors from fuelinjectorconnection.com.. work great
Old Apr 16, 2008 | 02:03 PM
Car: 1986 IROC-Z28
ya thunder im havin pretty much the exact same issues u are...i'll check those injectors out thanx
Old Apr 16, 2008 | 02:38 PM
thunder85's Avatar
Engine: 5.7L w/hsr
honestly, i don't know as u can tell just lookin at them. after i ran them for a bit, they were holding pressure and not leaking, had the correct resistance, etc. they seemed to pass every test that u can do in a regular garage, but they still sucked.
Old Apr 16, 2008 | 05:25 PM
Car: 1986 IROC-Z28
ok...well actually today after sittin at school for 7hrs it started right up
Old Apr 16, 2008 | 09:37 PM
87_gta's Avatar
Car: 87 GTA / 87 IROC-Z
Engine: 350 TPI / 350 TPI
Transmission: 700R4 / 700R4
Axle/Gears: Stock
i had the same problem, i replaced the injectors and it went pretty much completely away, it was strange be4 i changed them, sometimes like you said it will start right up, they turn it off and start it again and it will take a while then give you a cloud of smoke, my gta did that, my iroc still does it. i went with the ford injectors btw
Old Apr 17, 2008 | 05:04 AM
Car: 1986 IROC-Z28
ok thanx alot guys..
Old Apr 17, 2008 | 08:42 AM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
I have that same problem now, did you lose fuel pressure if you let the fuel pump prime and check it. Mine primes, and it just instantly drops to zero in about 3 seconds.
Old Apr 17, 2008 | 10:29 AM
thunder85's Avatar
Engine: 5.7L w/hsr
whiteirocz... put a clamp on your return line rubber hose and test then... if you still get the instant leakdown, its definitely injectors. leakdown that quick can also be a regulator gone bad.
chazman
Aug 28, 2018 03:25 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Fronzizzle
Aug 9, 2015 01:15 PM
BrianI
Aug 9, 2015 11:52 AM
