Can pre 90 TPI be used with speed density ecm
Old Apr 15, 2008 | 09:05 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
What kind of differences are there with the pre 90 (MAF) TPI induction systems vs. the MAP style systems? I want to convert an older vehicle (pre 87 bolt pattern heads) from Q-jet to TPI; I think the only thing that will fit is a MAF type intake system.
Can I just plug the cold start injector hole and be done with it? Are there other concerns/problems/impossibilities with trying to convert a MAF intake to MAP mode? Would I need to drill/tap any holes or install any additional vacuum nipples? Help....I'm clueless on this. Thanks
Old Apr 15, 2008 | 10:13 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Can pre 90 TPI be used with speed density ecm
Yes it can and I used a tee to get vacuum to my MAP. You could drill and tap a hole for a barbed fitting to feed the vacuum signal to the MAP.
Old Apr 15, 2008 | 10:48 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Cool....it's just that simple huh? How did you plug the cold-start holes and fuel rail?
Old Apr 15, 2008 | 11:17 PM
Car: 1989 GTA
Engine: 369 TPI
Well there is a lot more to it. I asumed you were talking about the TPI unit itself. You would have to convert to the 7730 computer. You would have to convert the wiring harness or get one from a 90-92 car. You could leave the ninth injector in place but not hook up the wiring. If you did remove it you can put a freeze plug in the runner inplace of the injector. You can get a cap for the back of the fuel rail. You would need to get the proper knock sensor and probably some things I'm missing.
Old Apr 16, 2008 | 07:39 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
You assumed correctly, I know about the computer part already. I was just wanting to know how hard it was to convert a MAF intake to be speed-density ready.
I was also wondering how much difference there was between the harnesses. I was hoping that adapting a MAF harness to a speed density system wouldn't be too hard, but I guess that's asking too much from GM.
Old Apr 16, 2008 | 08:17 PM
Car: 1989 GTA
Engine: 369 TPI
The later the maf car the easier it gets. On my 1989 model it was not hard at all. Every year you go back the more involved it gets.
Old Apr 17, 2008 | 04:02 AM
xurusaibobx's Avatar
Car: 1991 Camaro RS B4C
Engine: 5.7 350 TPI
if you got pre 87 heads dont you need to get either a corvette TPI base or change the heads to 87plus?
Old Apr 17, 2008 | 09:39 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
When changing to aftermarket heads you should get an aftermarket TPI intake anyway so you dont choke off your new heads with the stock intake.
There is a huge difference in the 85-88 harness vs the 89 and the 90-92 harnesses. In 1989 GM integrated the car harness with the engine harness so they're all in one wire loom. Before that it was two separate wire looms. But you can still rewire the earlier ones to work with the speed density system.
Steve78LT
Feb 24, 2016 12:15 AM
ezobens
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
86Base
Aug 8, 2015 01:34 PM
