How much oil?
Old Oct 1, 2001 | 08:39 PM
LeftTurn1LE's Avatar
How much oil?
I know this sounds retarded, but how much oil do you guys put in your 350? I'm confused because my original dipstick shows full at 3qts, which can't be enough. The Lokar shows full at 4qts, which is how much I'm using now. The handbook says to use 5qts, which seems to be too much. I thought they used 4.5qts. Am I just going crazy? Help me out. I changed the oil and filter last night and I'm running on 4qts of Mobil1 5W-30.
Old Oct 1, 2001 | 11:05 PM
breathment's Avatar
they use 5 qts, or 5.5 with the big filter..
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Oct 2, 2001 | 02:35 AM
rezinn's Avatar
I use exactly 5 quarts with an ac delco filter.
Old Oct 2, 2001 | 09:02 AM
Thanks, Are your dipsticks accurate, or do they read full after 3qts like mine does? Its the original dipstick, not the wrong one from another car. Also, I get a puff of blue smoke when I start the car if I use 5qts. It did not do that until after I changed the oil the first time, so I thought I just used too much oil. This is only the second time I've changed the oil since it has sat in my garage for an entire year. It does not smoke with 4qts.
Old Oct 2, 2001 | 01:59 PM
breathment's Avatar
mine reads full with 5.5 qts in.. hmmm stupid chiltons book. but i still think it looks like its mroe then just half a qt. make sure ur checking both sides, when mine starts to go down, one side will read about half an inch higher then the other.
- David
Old Oct 2, 2001 | 02:01 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
I use 5 as do most.... but I dont see how 5.5 could hurt
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, MSD 6A, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's, Accell 24# injectors
1989 Chevrolet Celebrity Eurosport <--DEAD AS OF 9/20/01
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
