Can Gen II heads work on traditional L98 block?
Old Oct 2, 2001 | 08:21 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Whats up everybody?
I have a question about reverse coolant flow heads working on a 88 L98 block? I have a set laying around the basement & I was wondering if they can be made to work? The casting number is # 10128374.........92-up 350........Gen II LT1,53cc,angle plug,aluminum, reverse flow cooling, 175/68cc ports.
I notice that the there are no coolant outlets for the intake manifold & thermostat housing. Do these heads use the vortec intake manifold?
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
Old Oct 2, 2001 | 08:33 PM
Guest
Guest
Posts: n/a
It can be done but it wont be cheap. You'd be better off selling those for a set that will bolt up with no hassles.
midge54
Dec 27, 2019 04:14 PM
Fast355
Dec 2, 2016 06:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
matthew911
Aug 12, 2015 09:38 AM
anesthes
Aug 8, 2015 09:37 PM
