Knock sensor different for 350TPI than for 305TPI?
Old Oct 3, 2001 | 02:24 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
I read somewhere on these boards that the knock sensor is different for the 350 than it is for the 305, but they didn't give anymore info. I just swapped my 305 for a 350 and am having pinging problems within certain throttle ranges and am wondering if I overlooked this in the swap. Can someone clear this up for me? Also, there is no ECM code for a bad knock sensor, right? So if I assume its bad (or incorrect), just replace it, right?
Thanks! I'm learning alot from these boards!
'89 TA - 5.7 TPI (L05, was originally a 305TPI), T5-WC, 3.08 Posi (Drum)
Old Oct 3, 2001 | 03:01 AM
rezinn's Avatar
Yeah the knock sensor and the est circuit are different. You need to get a new one for the 350.
Old Oct 3, 2001 | 03:10 AM
Mangus's Avatar
Transmission: T5WC
I feel dumb for asking, but what is meant by EST?
Old Oct 3, 2001 | 03:11 AM
Mangus's Avatar
Transmission: T5WC
nevermind. im assuming elec spark timing circuit.
ok, so im not totally sure what or where that is. im embarrassed, mind you. but how do i swap that out?
Old Oct 3, 2001 | 07:31 PM
Mangus's Avatar
Transmission: T5WC
Is it true that the EST circuit (ignition module) needs to be swapped too? Can anyone else confirm this? This is the first I've heard of it.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
