How to bypass the knock sensor?
Old Oct 3, 2001 | 11:01 AM
formula5's Avatar
I have a 400 sbc w/tpi and want to bypass the knock sensor.My motor harmonics is way different than stock also.Remove it from the block and keep it pluged in?Is there a better way?I did work with cars before knock sensors.So I'm not scared to bypass it.From what I understand there is no knock sensor for a 400.
Old Oct 3, 2001 | 11:14 AM
crucial's Avatar
The onyl way to bypass it is to take the wire that goes to the knock sensor and ground it THROUGH a 3.9Kohm resistor. You can find one at Radio Shack for 10 cents.
1991 Z28
357 4 bolt main block, TrickFlow 23 degree heads, CompCams CS270HR cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, 2500 stall, bullet proof 700R4.
Old Oct 3, 2001 | 10:13 PM
airdeano's Avatar
the above is fine, but you will need to have
the chips advance curve redone. to dependent
on the knock sensor being there. plus remove
the knock sensor diagnostics. and be careful
on WOT passes. you probably will have underlying detonation. start low on the curve
and work upwards.
been there and bought a couple of pistons and
ring sets.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
