starting problem
Old Oct 3, 2001 | 01:29 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
starting problem
Trying to chase a starting problem. '89 L98. Fires up, then dies a couple seconds later. Does this repeatedly. My laptop died so no scan data right now. Guesses? Getting new MAF relays on the way home tonight (man I wish I'd already done the MAP conversion) and will attempt to get another laptop borrowed.
Old Oct 3, 2001 | 01:33 PM
86Trans Am's Avatar
any codes and are you getting fuel?
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Oct 3, 2001 | 02:41 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I didn't have time to grab codes; doing that when I get home. Yes it's getting fuel, as the engine starts and sounds normal for about 2 seconds, then dies.
I've tried the ARAP code (which used to work) and also gone back to the stock APYU with the same effect.
I hope to have my diagnostic tools back together tonight.
Old Oct 3, 2001 | 03:58 PM
mckenzie's Avatar
sounds like just your fuel 2 sec run is working. might want to see if you lose fuel pressure when this happens.
86 iroc 305tpi auto. mild cam
Old Oct 3, 2001 | 05:31 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
'twas as I thought. Swapped the MAF relays and all is well again. Gotta get my laptop cable working tonight so I can start tuning!
Thanks for the suggestions...
Old Oct 3, 2001 | 10:16 PM
airdeano's Avatar
check to see if you are getting an injector pulse. if the fuel pump energizes for the primary
2sec and you start, runs and dies. check the
pulse signal to injectors. sounds too close
to the VATS signal diagnosis. possible oil
pressure switch open to fuel pump relay.
Old Oct 3, 2001 | 10:19 PM
92RSB4C's Avatar
I must know how you got your laptop to scan data! I've been trying but after 20 tries I'm starting to give up. Help Me!
BOMB BIN LADEN I see dead Afghans in dead Fords on the side of the desert path.
[This message has been edited by 92RSB4C (edited October 03, 2001).]
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
