ZZ4 cam on a 305 TPI
would a ZZ4 cam work on a modded 305 TPI (heads, exhaust, prted intake etc) what about the LT1 vette or the 350 IROC cam(came stock in my car)
1987 Black 305 TPI 5spd IROC, seems to be fully loaded, but can't find RPO codes.
AIM: IROC 5spd
AIM: IROC 5spd
yes, it would work, but isnt your compression
lower than 10:1? to make full advantage of the
ZZ4 cam, no less than 9.6 would be the lowest.
airflow would be the next consideration.
some intake reaming and larger tube runners
would be a must if you are gunna do some high
rpms.
rpms.
An lt1 cam will work nicely on your 305!!
Anything is better than that stock 305 cam.
One Tight Teal green 91 RS (my first car
All Rustangs suck!!!!
5.0 TBI with Auto trans
Z-28 wheels
K&n with dual snorkel intake
Tx Smog Pump Delete option
Valve cover breather
Rapid Fire plugs with Accel ignition wires,coil,cap and rotor
Flowtech headers with flowmaster and Half way cutout
B&M shift kit with trans cooler and hurst hotshift fulid
Hypertech thermomaster chip
96 LT1 cam with
New liffters and timing chain
All the free TBI mods
[This message has been edited by ZRATED (edited October 03, 2001).]
Z-28 wheels
96 LT1 cam with
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
<font face="Verdana, Arial" size="2">Originally posted by ZRATED:
</font>
</font>
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
I need a cam anyway, i am running some truck cams and heads now, i would like to replace the heads with stock 305's that have been ported and polished, then SLP runners and a ported baseplace and plenum. I need a cam to match. Any suggestions? looking for power upto around 5500 if possable. My brand new stock 305 sould handle reving this high repeadedly right?
AIM: IROC 5spd
http://www.geocities.com/chevy5spdiroc/87Roc.htm
AIM: IROC 5spd
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
Instead of buying a stock set of 305 heads, why not look at some World Products 305 torquer heads for about the same price, or a few more bucks. $700 assembled isn't that bad for a pair of heads. You can get them pretty much anywhere, I don't know the cheapest place though.
Later,
Jesse
Later,
Jesse
Sanjay
Aug 12, 2015 03:41 PM
